In the "Multi-zone air flow simulation results" windows in the simulation result, there's a box showing the flow rate in each opening. For the openings that have both supply and extraction, the text is cut off and cannot be read (see attached file). Is there any way to see the results?
I have been unable to reproduce this issue here as of yet. Could you please confirm the version number in the bottom left corner of your Hevacomp main screen?
Shane Regan | Principle Building Performance Support EngineerHevacomp to OpenBuildings - A complete guide for every user | Bentley Communities
The main screen shows 25.06.9
Design database shows: 25.06.6
Thank you
Can you update your software to the latest version? Information on this process is available here, you require update 29 - Please take careful note of UAC requirements, admin log in, and any extract path changes you may need to make. The area causing concern on your results page has been resized - along with the font that is used - and you should be able to see all of the data without it being cut off.
Duncan Brown
