Any issues with ArcPro?
I have a Cube installation using ArcMap, whiich I installed before installing Cube.  Our agency is moving to ArcPro.  Are there any issues I'll encounter when my locally installed AcrMap dissapears?
  • CUBE (version 6.#.# and earlier) uses ArcGIS Engine for its geo-database functionality.. CUBE installer comes with its own ArcGIS Engine installer,  if the user does not already have ArcGIS Desktop/ArcGIS Engine. Since ArcPro is a different software to ArcGIS Desktop, moving to ArcPro should not affect CUBE functionality. The only thing you need to do, is to re-install CUBE after you upgrade to ArcPro to make sure any CUBE ArcGIS Engine dependencies are handled properly.
