i'm working on transit transfer fare policy analysis and i wanted to know if it is possible to assign different discounts when transferring within the same fare system. for example the first transfer you will get full discount (zero to pay) and 2nd and third transfer you will be discounted to 20% and 30%.
This is not currently possible to do. You can only apply fares for all transfers. We do not have the provision to apply fares for nth transfer. We will look into this feature as a possibility for a future update.
