I can't run CUBE or specifically TRIPS program into MVPUBM module. How to solve the problem which can running CUBE Trips on CUBE Version 6.4.3 because the data model files need to use CUBE Trips.
My problem show in the following picture.
I am not exactly sure what the problem could be. Could you try the following?
