I
I cant open a catalog because i think a path is wrong. How can i fix the path issue or this issue?
When you move a complete model to a new location and open the model in CUBE, it should automatically update the file paths. However, if individual script and application files with incorrect paths are copied to the model folder, then this issue could happen. There might be other reasons too. It is better to do a search and replace in all application and script files, to update the incorrect paths with the correct paths. You have to update both .app and .s files. You can use Notepad++. Go to Search >> Find in Files and try something like below. I would suggest taking a back-up the model before running the search and replace.
I did what you recommended but i still have the same problem. I also created the project folder to see if i could open the catalog then fix it manually, but nothings seems to work. what else can i try?
In the screenshot you sent, it looks like there was not any replacements done. The file filters should be *.app;*.s. I noticed you used '*.app,*.s;'. The comma should be replaced with ';'
