HOW CAN I BUILD A PUBLIC TRANSPORTATION NETWORK FROM A SHAPE FILE? AND HOW JOIN THE PRIVATE TRANSPORTATION NETWORK WITH THE PUBLIC TRANSPORTATION NETWORK?
Please have a look at this post:
communities.bentley.com/.../how-to-import-a-line-shape-file-shp-into-a-cube-voyager-pt-line-file-lin
Hi Filippo, In the public transport course that you teach for one or more users?
Hi Ofelia, do you mean the online training course here? https://citilabs.teachable.com/coursesThese courses are designed for one person per purchase/activation because they track your progress and provide a certificate at the end. If you would like to contact me directly I can help organise multiple access if you are under CUBE SELECT/maintenance.oliver.charlesworth@bentley.com
