TP+ Legacy script
I want to check how well past models forecasted today's traffic. To do that, it means I have to run TP+ script in 6.4 since these models were created using TP+. I get the following error " Unable to execute the Task Monitor run. Check that the Task Monitor (TMonitor is in your TP+ directory ['\']." Any help to fix this error is greatly appreciated.
