bentley coax
While uploading datavld.ma in Bentley map it is not showing coax icon. I have to design coax network designing but coax component are not showing. Or  how can I upload bentely coax and other component dll in software so that I can see these tools in Bentley map or microstation. Please help
  • Hi Laxman Prasad:
    The file you mention (datavld.ma) is not a file to be used for Coax network design. The Bentleycomms software is available on Select Services for download, but normally much preparation work must be completed before the software can be used. There must be spec files built, Cell libraries composed, coordinate systems assigned to seed files, etc.
    Please file a Service Request if you need additional information concerning using the Bentleycomms software suite.
     Thank you,
    Dan Gordon
