Hi
I am using 'MicroStation V8i (SELECTseries 2)'. My question is, is it normal the software to this kind of situation? (Please read the my experience below.)
I have 3-year old .dgn file. Not everyday but none of the week that i haven't open the file for keeping the strand updates or whatever updates needed. When I was done inputting, I closed the file by clicking the 'X' button on the upper right corner of the window then there was a dialog box poped-up asking me to save the changes. Supposedly, I have to click the 'Yes" option but accidentally i clicked 'No'.
I understand and expect that the changes weren't saved. But unfortunately, not only the updates were lost but all of the cells - stand distances, house counts, strands, poles- were lost which supposedly it's only the updates on that certain time wouldn't be saved. Only the text elements and line elements were left. I thought it was only a computer error but the same thing happened to my companions.
Can anyone help us? Is there any software settings to change?
Oteep
Hello Oteep,
you can go to Workspace > Preferences > Operation > and turn on the setting 'Automatically Save Design Changes' - then it automatically saves changes to the DGN file and the dialog does not appear anymore when you exit MicroStation.
Regards,Anu
Answer Verified By: Oteep
Are you using any applications with MicroStation V8i SS2?
Carl Myhill
Technical Support Engineer
Bentley Systems
Unknown said:Hello Anu, thank you for your response. I did your suggestions but still the same dialog box still appear. I think theres more settings needed to set-up to protect my file from unintentional destruction. Regards, Oteep
If this file is very important like a master ref file and only changes occasionally you should turn on History feature secondly it should be backed up often especially before editing.. it is an old file with some legacy data and features..
I suggest you make new version from clean seed file ref attach the original and copy through all the data , then use the compress all options and then verify repair feature these 3 steps get rid of most problem objects that may have crept through and started corruption..
Then after all this enable the history option on master files is just good work practice...
Other option also a good work flow is to make a BAK file or backup of the file before you edit it. or in between big changes but the settings of autosave in your prefs is a must have...note that hind sight is great and easy for me to say you should do this or that as I have lost stuff too because I didnt do all the things I recommened..
BTW in one place I worked at if you opened a dgn say at 9amm and worked solidly on it without getting out of that file say until 11 am making lots of changes and additions if the microstation crashed or locked up froze etc for what ever reason I would loose everything I had done for the ENTIRE session in 25 years of using ustn I never experienced this anywhere else, its like the server didnt write to disk and had some sort of giant cache or virtual drive and wrote it to hard drive after you closed the file... it didnt happen if I copied the file to my c drive.... and copied back to network later.. I never got to the bottom of it and nobody to date has ever been able to explain it...
I always promoted ustn as a dynamic write/ saving cad package and was better over acad in that respect that you cant loose everything in a session only the last one or to actions or elements that either contributed to the crash or during the crash....maybe thats whats happening at your end too? talk to your IT guys ..
Lorys
