I have a project here in which I need to populate the OWNER of every element within the project bounds. However, the only way I know of to do this is to manually select each individual object and do so. With something like 20,000 elements in the project, this is unfeasible. Is there a way to do this faster? I'm perfectly comfortable writing VBA or in any other language (in fact, I'm using an AHK script to speed up the process somewhat), but I have been able to find no VBA documentation on the tools or extended data structure that come with Bentley Comms, so I have no idea how (or if it's even possible to) access them via VBA. I have been unable to find any other obvious way of doing this either; i.e. I can't seem to locate any tool that lets me see the data on all the elements I currently have checked out, for example. Any help would be greatly appreciated.
Hi Darin--
For most features in BentleyComms this info would have to be populated individually. It would be possible to corrupt the database in some cases by globally updating certain fields. However, there are some fields in some of the modules that could be populated globally, but I would need to have more detail on which module you are using, and what exactly you need to populate. Please send me an email (dan.gordon@bentley.com) with a phone number where I can reach you, and i will give you a call.
Thanks!
