I have a dwg file attached to a .dgn and some lines look very thick, when they should have thickness 0. Any solution and / or the reason for this? Thank you.
David--please submit this question to the MicroStation forum. Someone from that product line should be able to help you with this.
Please email me about the Fiber issue...dan.gordon@bentley.com.
thank you!
