An attached .dgn file is not displayed when attaching. In the image you have San Miguel. Dgn where Pueblo Libre.dgn is attached. No Free People is displayed. When doing the inverse test, attached San Miguel in Pueblo Libre, both files are observed. Please your support.
Greetings.
Hi David--please open each file one at a time and do a fit view. the contents you see should be visible with either file active and the other referenced...be sure your view setting is set to ALL and not ACTIVE ONLY.
Dan
Dan, thanks for answering my question. I found the error. The files that I normally use have the model assigned to DEFAULT. My file was in RED, and therefore at the time of using the same configuration was not observed. Just update the model name and you're done. Thanks again for taking care of my query so fast. Greetings.
David Pacuri
david.pacuri@entel.pe
Entel Peru SA
+51 981516299
Hi David--
Yes, the reference files will be in red if the current directory structure is different than when the file was reference attached...and you can detach and re-attach the file to correct the directory path, or as you mention, refresh the path and the reference files will be visible. Thanks for your update and reply.
Dan Gordon
