Good day. Upon reviewing an existing sheath, I noticed there are fibers in the design column of the fiber information section of the review window, and it affects the total fiber count.
Does anyone know how to remove these fibers without deleting and replacing entire spans?
Hi Brandon--
Please send me an email directly at dan.gordon@bentley.com with your contact information, and i will get in touch with you about this issue.
Dan Gordon
Hi Riribej--
If there are Fiber counts listed in the Design: column of the Fiber Information Override section of a span review, this indicates that the Populate Global command was run and Fibers were added to the Override>Design column. These fibers can not be removed from the Design column after Populate Global has been run. The user can subtract the number of Design fibers from one of the other categories and Override.
The fibers in the Design column can be removed manually from the database. For help in doing this, please send your contact information to dan.gordon@bentley.com and I will contact you.
