Masterpath not found (Bentley Expert Designer)
I try to open a project and the system gives me the following error, what should I check?
DBWin image
error.txt
13396: [e:\Builds\exdc081109858\Source\Utility_Applications\ExpertDesigner\ED\CHGraphicalUserInterface\ExpertDesigner\WRListView.cpp - 397] - CWRListView::OnContextMenu(CWnd*, CPoint point).....
13396: CUtilFunction::GetProductType()
13396: [e:\Builds\exdc081109858\Source\Utility_Applications\ExpertDesigner\ED\CHGraphicalUserInterface\ExpertDesigner\WRListView.cpp - 2119] - CWRListView::OnCustomAction(UINT uID).....
13396: [e:\Builds\exdc081109858\Source\Utility_Applications\ExpertDesigner\ED\CHGraphicalUserInterface\ExpertDesigner\UpdateViewObject.cpp - 94] - CUpdateViewObject::CUpdateViewObject() - Constructing
13396: CCHWorkManagement::WorkRequestAction()
13396: CCHWorkManagement::get_VWMS()
13396: CCHWorkRequest::Load()CCHWorkRequest::Init()
13396: CCHWorkManagement::get_CustomWorkManager()
13396: CCHCustomWorkManager::CustomWrEvent()
13396: CCHWorkManagement::GetWorkFlowsRecordSet()
13396: CCHCustomWorkManager::CreateWorkspace()
13396: CCHCustomWorkManager::GetCommsDBConnection()
13396: Inside LockRecord
13396: Oracle EM
13396: CCHCustomWorkManager::CheckWorkspace()
13396: Check for workspace SQL - select NVL(max(to_char(A.workspace)), 'No Record Found') As X from WMSYS.WM$WORKSPACES_TABLE A where workspace = 'KPP_IT_TEST_V24'
13396: CCHCustomWorkManager::CreateCommsDesign()
13396: Oracle EM
13396: CExpertDesignerCore::get_VersionManager()
13396: CCHDesignEditor::CreateDesign()
13396: CCHDesign::CCHDesign()
13396: CCHDesign::Init()
13396: CExpertDesignerCore::get_LinearAllowance()
13396: CCHDesign::Save()
13396: CCHDesign::IsObjectCommittable()
13396: Oracle EM
13396: In CCHCustomDesign::DesignSave
13396: CExpertDesignerCore::get_GISType()
13396: CCHDesign::CreateDGN()
13396: CCHDesign::FormatWorkspaceName()
13396: kgl_Design523969
13396: CCHError::AppendContext()
13396: CCHError::AppendContextParam()
13396: CCHDesign::CreateDGN() - Err
Expert Designer Version
Thank!!!
