Problem displaying item name. Bentley Fiber
Initially, when naming a fibernode element, there are no drawbacks. Even after making ´´Post´´
 After applying ´´Merged to parent´´ and consulting the element from a new workspace, I find the following error when displaying the name:
  in the image I share its properties Are there any suggested solutions? Thanks,
  • Hi Miguel!
    What version of Bentley Fiber are you using? Have you recently changed the cell for the fiber node?
    thanks,
    Dan Gordon
  • Hi Dan
    The Bentley fiber version is 08.11.09.422
    At no time were changes made to the fibernode cells.
    Thanks for the prompt response.
    I await comments
  • Hi Miguel--
    If a text style is missing, the text will be turned into a dot. Check the following:
    1. Do an element information on the text of the node and under 'Contents' check the Text Style used for the Node name.
    2. Open the menu item Element>Text Styles to see if this text style is in that list.
    3. Check the DGNLib file (in the dgnlib folder of the project on the folder) to be sure that text style exists.
    4. Go back into the element information dialog and click on the acutal Node Name text under the Contents section. This will make an ellipsis appear in the right hand side of the cell...click that ...ellipsis and select the correct Text Style for your Node name in the Edit Text dialog that will display. Also check the 'Apply changes to all text' box.
    5. Click in the Key-in window where your Node name should be displayed, and then click [ENTER].
    6. Now place a new node, and check to see if it works.
    Hope this helps!!
    Dan Gordon
  • Also Miguel--there is one more place to set the Text Style for Fiber nodes--in the fiber module, go to Fiber/Copper/ISP-Setup>OSP>Annotation and make sure the same Text Style is used for Fiber node in that list....
    thanks,
    Dan
  • Hi Dan,
    These were the results.
    1  Do an element information on the text of the node and under 'Contents' check the Text Style used for the Node name.
    When selecting the point, the contents option is not displayed
    Ok, activated
    Ok,
    It is observed correct when selecting the Node
    The test was performed and no good results were obtained after applying merged
    Is it possible that some step was not applied correctly?
