Hi.It is possible to see fields loaded in CA table from feature/property navigator/data browser? (see screenshot).
These are the versions:Expert Designer: 08.11.09.858Bentley Comms: 08.11.09.870Thanks
Hi Miguel--
What is the end result that you want to achieve by bringing in this information to data browser? Are you just needing to view this information, are you looking to export it into a report, or is there something else you are trying to achieve? There may be some other alternatives we can use to obtain your desired results. Let me know and i will see if we can help you.
thanks,
Dan
Hi Dan,
we need it to be observed in that space, so that the user can extract a complete report of information.Thanks
Because that information is not an actual graphical feature, it cannot be displayed in data browser. However, if you could send me a complete list of all the information you would require in your report, i will see if i can help you get a report designed to accomplish that.
We need some of those fields to be visible in some kind of report within the tool. Not only display it from the populate/Data option
Hi dan, Is there any news?.
Thank you very much
