Is there a way to place utility poles in OpenComms Designer, that fiber cables are attached to? I need to place these poles with the pole numbers, for a project and I knew how to do this in the older version of Comms, but not in this version.
Hi Brian--
Yes, the method to place poles or peds in OpenComms Designer is to use the Facilities tab…this used to be called the Strand module, but is now called Facilities…use the place facilities command and when you begin the command, you will probably recognize the dialogs that come up, as they have not changed since the older version of Comms.
Facilities Placement (bentley.com)
Dan Gordon
Thanks Dan!
