I am aware that currently MicroStation V8i is a pre-requisite for Bentley Coax and Bentley Fiber.
Just wanted to check and confirm with the community, if there is a standalone version of Bentley Coax and Bentley Fiber similar to Bentley Map Standalone which does not require MicroStation.
Tx
SRG
SRG,
Hello, I'm the ISD for the Comms solutions. Thank you for visiting our community. There are no standalone versions of our Comms products. All of the design products (Coax, Fiber, Inside Plant) require that you have MicroStation installed. However, there are two veiwing products that you might consider: Comms Power View and Geoweb Publisher for Comms. CPV is a standalone product for viewing and redlining Comms intelligent drawings. GWPC is a connected viewer that provides the same functionality. Both products provide full viewing of the Comms data with searches of information about the features; however, you cannot modify the data with these products. I hope this helps. Please let me know if you have any other questions.
Thanks Mike for the clarity.
I will get back to you in case I need more details.
