When i start application (Fiber v8i) i don't see Bentley Communications menu, i don't have access to modules (Strand, Fiber etc.), what is wrong? or how to enable this menu? While startup the application below shown Text window is popping up.
I was followed the installation process as the document “readme_BentleyCommunications.pdf” and applied workspace macros parameters as mentioned.
I've tried to manually run cismain.ma (Utilities -> MDL Applications) but i get information as shown below
I am using the software’s in my system as mentioned below
System OS: Windows 7 (32-bit)
Database: Oracle Database 11g Release 2 Client 32-bit
Bentley MicroStation V8i (Select series 3): 08.11.09.459
Bentley Fiber: V8i (Select series 3): 08.11.09.123
Is anybody there to answer my question? or do you need more information??
Advance thanks for the quick reply
Hi Ramesh,
It seems that in the Schema the path is not properly mentioned and the path its searching there is no .ma file exists, so make sure the .ma file is in the proper project folder.
If we can have a live meeting I will suggest you to fix it.
Anil.
Hi Anil,
We could able to trace the issue, there is a minor typo error in the setting the configuration of the path value. We have rectified it and we could able to see the communications toolbar.
