Hi All,
I want to clarify such a situation.
Is it possible to develop add-ins for Synchro 4D using appropriate SDK?
For example, is it possible to create some importer and embed it into Synchro 4D?
Thank to all in advance.
I have the same question, is it possible to make plugins/addins for Synchro or interface with the application using API?
I think it is possible, but it depends on Apache thrift as a web server and a further problem here is the availability of Api samples and documentations.
Hi, you can create custom apps that GET/SET data, but not embed the app directly into the PRO interface. I have been working with a company called Engyn that has developed a visual scripting interface that is quite flexible and could be helpful for you.
