How can i import map models (i.e. Autodesk Infraworks) into synchro pro and on the right coordinate?
Hello -
You will need to export to .FBX then import into SYNCHRO Pro. If it is texture heavy you may consider dumb down the Infraworks model a bit. Pro is not equipped with geo-location functionalities at the moment but if you are only looking to see your design model aligned with your site model created in Infraworks Pro does keep the translation and respects. In simple terms, they will be imported in the right place and look right.
