Hi All,
I'm having trouble opening an IFC 4x1 file. I'm Working on a Roads and Bridges Project. With ther roads (IFC 4x1) I can't see the geomtry. Even if the file is imported correctly. A transormation doesn't help.
Best Regards,
Carlos Montellano
Hello - thanks for making the suggestion.
The following IFC Schemas are supported per our Help Documentation:
If you'd like to make a request for us to start to support additonal schemas, please submit an idea to https://construction.ideas.aha.io/. Our product team will be reviewing your requests.
