Hi All!
I would like to know if it is possible to modify the title text shown in the footer of the Gantt chart export view because I would like to get the text in spanish.
If not, It's possible to edit a new footer to make it look like the "Show Synchro footer" one? How I can add some rows? The footer editor only let the user to add only one row.
Thank you in advance!
Hello -
Footer only allows for two rows. You will need to use both footer and sub footer in this case. To start, go to File> Print. In Print window, go to Header/Footer/Legend tab. Click Add for Sub Footer to add an additional row for footer.
By default only one row for footer is enabled.
