Hi all! I would like to know if it is possible to filter by more than one parameter in Synchro. In addition to the parameter "norte" (shown in the attached picture), I would like to use another parameter, for example "sur".
Does there is any method to do this?
Thank you in advance!
Hi Juan,
If you want filter 2 values (Norte y Sur) for example, you can try this in your user field :
o For AND behavior, use && between 2 values to match both values (e.g. >10 && <20)
o Use || to indicate OR when entering 2 or more values (e.g. A || B || C)
Stéphane
Answer Verified By: jdarevalo
