Hi all,I'm trying to import directly a 3D DGN model from microstation to synchro, but no geometry comes through. The model has been done in local coordinates. There is a Microstation DGN in the list of readable 3D, do I still need to use a plugin or am I missing something?
Thanks for your answers Quan and Jacqueline.
So far I'm still being unsuccessful. I've tried the dgn and i.dgn
I've installed the Synchro plugin 060101 to match the synchro version I'm current using, however I can't find it in the applications, do you know where can I find a tutorial how to use this plugin?
Cheers
Hi -
If you open SYNCHRO Pro and press F1, you will be able to access the Help documentation. You can search for the keyword MicroStation CONNECT.
Step-by-step instructions are available for Using the MicroStation CONNECT Edition Plugin.
Answer Verified By: Indrawan Wijaya
Thanks Jac,
I managed to export the spx using the plugin but synchro is still not reading the 3D geometry. I've raised a support ticket and shared the file with synchrosupport@bentley.com,
