Hi all,I'm trying to import directly a 3D DGN model from microstation to synchro, but no geometry comes through. The model has been done in local coordinates. There is a Microstation DGN in the list of readable 3D, do I still need to use a plugin or am I missing something?
Thanks Jac,
I managed to export the spx using the plugin but synchro is still not reading the 3D geometry. I've raised a support ticket and shared the file with synchrosupport@bentley.com,
Cheers
Jacqueline tengo problema en encontrar el MDL en MS Connect. He seguido los pasos que indicas poro no logro encontrar la aplicación.Donde se instala el complemento?
Close this thread, John question is answer from this link .
Plugin para MicroStation - SYNCHRO Forum - SYNCHRO Construction Solution - Bentley Communities
Thank you,
Indrawan
