I am working on a large merged .sp file which contains Architectural and Structural Objects but I want to synchronise part of the file (Structural objects) from a different dwfx or spx Structural model file. Obviously if I choos to sychronise the whole of the merged .sp file it will completely replace this with the Structure (.spx) file. Is it therfore possible to sychronise part of the merged file including resources.
thanks
Hi JA,
As I understand from your post, the architectural and structural models were imported merged, as a single external source. Therefore synchronizing will refresh all the models from this external source.
If you want to update just part of this source, I believe the only way is to set it up in the original import software. Otherwise, you'll have to do something more manual by deleting the objects you want to update, importing the new structural model and deleting everything but the updated objects. Hope that makes sense.
Cheers
Hello - For synchronisation to work as expected and properly, the scope of the original import must be the same as the scope for the synchronisation. If you'd like to synchronise A and B separately later on without losing work done in Pro, A and B must be imported separately in the first place. Hope this helps.
Thank you so much. This is very helpful
Thanks so much. Your response is very helpful
