While trying to print/export image of a 3D view with 3D annotation or markup (for project reviewing), all my text (from this annotation and markup) are printed in a very small size while the box still has the correct size.
I ended up with something unreadable as you can see in the attached pictures. As you can see, this is weird.
Am I missing any text font size parameter ? Because, I searched in most of the parameters of my file and I can't find anything.
Or is it an graphic issue ?
My 3D view :
My Export Image :
My PDF print :
Thank you for reading my question.
Hello- I am not sure if this is the right answer however my guess is that this is because of resolution. An workaround for your consideration which is to take a screenshot instead of exporting from 3D View then combine multiple screenshots using adobe PDF. If you want to provide an SP for us to have a look please post it here. Thank you!
Well, this is what i'm doing right now. But i'll prefer to have a better workflow since I often use those markup and comment. Moreover, I feel like i'm missing something since we can see the box in the correct size but not the text inside it.I can't upload a .sp file here, so i'll send you an email with it. There is nothing specific in this file, juste a simple 3D object, a markup and a comment.
Is it maybe not meant to be used like this ?
Screeshot :
saved as image :
Thanks for letting me know. Please report this to Ideas if you feel that this improvement will benefit not only you but also the majority of our users. You can submit an idea by scrolling to the top, and click Ideas.
I'll do it, thanks.
Thank you!
