I downloaded the plugin for OpenBuilding to export to .spx file to be able to put into Synchro software a model from OB.
However I cannot find it anywhere.
In v8i it was on utilities => MDL applications and it is not the case here fr the Connect version.
I also did not find any documentation for this addin.
https://softwaredownloads.bentley.com/en/ProductDetails/2917
Do you think you can help me ?
Thanks.
Moved from OpenBuildings forum to Synchro Forum
Hi- to bring the models from OBD to Pro, you will need to use one of the options below:
Option1: Obtain dgn, i.dgn or bim then open SYNCHRO Pro, choose File> 3D, then directly import of .dgn, i.dgn and .bim Option2: Publish i-model (i.dgn) from OBD, then open it in MicroStation where you can use the SYNCHRO Pro Plugin for MicroStation which can be downloaded from: https://softwaredownloads.bentley.com/en/ProductDetails/2917Option3: Sometimes as a workaround, you can consider export 3D dwg then import that into SYNCHRO Pro.
Documentation is available within SYNCHRO Pro. Press F1 then search keyword MicroStation Connect Edition.
Please try out the above options.
I downloded the plugin and installed it but nothign happens in Microstation connect edition.
I do not have the MDL applications.
I think the last version of the installer is not working properly version 06.02.01.03.
Or how can I check that it is correclty installed ?
The other options works but :- or the geometry is imported as one block and elements are not broken down,
- Or data is missing from the native software.
Hi Philippe
Look at the attached link it may help you to convert OBM dgn file to spx format, but it might be a problem in the future that you want be able to update the file.
I have very little knowledge of Synchro.
https://www.synchroltd.com/plugins/
Mark
Hello Mark,
Thanks for your answer.
This page is for Synchro plugins for V8i version. They work fine.
However for the connect plugin, you need to install the connect version that you can download into the Bentley software page as put by Jacqueline Chen above.
It is this one that does not work.
