Hello everyone,
Can we somehow improve the Exportation IFC of Synchro?
For example, It seems that most of the colors of the models will be dissapear after the export.
Thank a lot
Hi- Did you view the export of IFC from Pro in two distinct products? Or is this just one product that you are using to baseline?
I've tried on BIM Vision, REVIT and BIMSync but On BIM Vision and REVIT, there is nothing appeared.
BIMSync is the only platform that I can view this IFC files from SYNCHRO Pro. But all the colors are dissapeared
Hi- Please go ahead and submit this as an improvement in Ideas! Please be sure to submit your SP with reference of the Pro version, attach the exported IFC and be specific about the issue that you are trying to report. Thank you!
Hi colour problem as well in ORD, can someone have an idea how to do it?
Hi - Can you be more specific about your question? What does it mean by "color problem in ORD". Did you mean that you couldn't see color after IFC is imported into ORD? If yes then please find the forum for ORD and I'm afraid this forum is specific for SYNCHRO products.
