exporting eva chart and gantt animation
i have a problem that my eva chart is not moving as the gantt is when i export them, how can i fix that? thank you
  • Hi Amalia-
    From experience and without actually seeing any screenshot or your file, I believe you will need to size the EVA chart a little so the curve is positioned within the EVA window in the User Interface before you go into the Export Animation window. Hope this helps.
Reply
  • Hi Amalia-
