I'm wondering if it's possible to render using IRAY with a textured plane in it. I'm trying to figure out now if I will have the image in dwg then import it to Synchro if it makes any difference.
Is there a proper way to do it?
Thank you.
Hi April - I recall that this is not supported at the moment. I think you will lose texture when exporting with Iray.
Thanks Jacqueline! I did lower down the image so it wouldn't touch the model and turned out OK after exporting. But it really didn't serve it's purpose.
