Hi, Is it possible to connect Synchro with the Primavera SQL Lite database using primavera API? The issue is when we use a standalone version the easy installation will be by using SQL Lite database. There is no information I could find a way to connect synchro with SQLLite database using API.
If this is not possible what is the alternative way to connect to the Standalone version of Primavera using API?
Will be helpful if someone can provide some insight on this.
Hi Suresh,
Any information we have regarding setting up and connecting SYNCHRO to P6 database using the API is provided within SYNCHRO Pro Help documentation. The API itself was developed by Oracle and would recommend reaching out to them for any questions or troubleshooting.
Since we do not have much control over this, our recommended workflow is to use P6 XML format for interoperability with SYNCHRO Pro.
Answer Verified By: Arpit Prakash
