Synchro Plugin for Revit 2021
Afternoon
Quick question, has a Synchro Plugin been released for Revit 2021 yet? If not is there any idea of a release date?
I tried what I had done with Revit 2020 and copied the ExportSP.addin from the 2019 Addins folder into the 2021 folder and the plugin did show up in the Revit 2021 ribbon, but when I tried to export a 3D model it failed.
Also is this page still being updated and still the main place to check for plugins - https://www.synchroltd.com/plugins/
Any help/advice would be gratefully appreciated
Cheers
Scott
