Looking for online training for anything SYNCHRO? You can do that at Bentley LEARN.
There are courses and learning paths for SYNCHRO 4D Pro, SYNCHRO Control, SYNCHRO Field, and SYNCHRO Modeler.
Synchro Academy Link is not working.
Same happens with me
All,
The Synchro courses are now available on Bentley Learn - https://learn.bentley.com/
Select SYNCHRO as the Brand and then click on Find Training.
You should see the following courses.
To choose a course, simply click on the course name in green text on the left side. You will have to enter your account credentials to access the course.
You should then see the sections page.
Simply click on the link below the Launch column to access a section.
Hope this helps.
Paolomee
It doesn't have Course named "4D Data Analysis using Power BI. It was there in Synchro Academy. Can you send me the link please for this course.
Hi, Is it possible to get a certificate somehow? I know previously it was part of the quick start course for synchro but it doesn't seem to be now.
