Failed Primavera XML on some systems.
We are many user of Synchro where I work, all the same version. Some of us can do primavera XML import, all data imported... Others, when trying the import, will process the import, no error messages, just no content imported. Is there something missing in some of our systems like odbc driver?...  Just can't figure out yet what is missing in some of them?....
  • yes. many user failed doing import with the sames files where import worked on other systems
  • Confirm a new bench of tests... I gave  4 test files Primavera XML to a few users for testing, Exports done a few months apart. Some users can open some, others not... I personally can open all of them. What is different in my system compare to others is that I am the one responsible to import many cad and GIS format, various database, more than the others... I have more software and conversion tools that cam import/convert over 400 file format. Many extra drivers, odbc, plugins installed on my systems by those tools, way more then my colleagues...  That is why I think they are missing something, a plugin, driver. that was installed in my system.
Reply
