Hi
I am trying to get resource status to be selectable on my ipad, but no matter what I did, it does not show up.
So this were setup
Assigned worker with emails to every task.
Assigned resources to every task.
Did I miss out something?
Hi Edgar,
Please make sure you follow the following steps to set up your project.
1. Create Resource Groups from Resources
Resource Groups aggregates 3D Resources as individual packages by responsibility. You can create Resource Groups by selecting desired resources > right-click > Resource Groups > Create Resource Groups from Selected.
2. Set up Resource Statuses
Resource Status defines detailed steps and milestones beyond construction activities.
3. Create Human Resources
4. Assign Resource Group Personnel
By assigning personnel to Resource Groups, you can define responsibility for each resource group packages. You can select a Resource Group > Go to Resource Group Properties > General > Personnel > choose from the Human Resources you have just created.
5. iModel Synchronization
Transaction synchronization to iModel needs to be finished before the next step. The transaction status can be checked in Transactions > Transaction history.
Thanks!
Siqi
Answer Verified By: Edgar Chan
The solution that Siqi provided above is for SYNCHRO Field, which only works with SYNCHRO 4D Pro v6.3.1.2. Can you please confirm if this is indeed the version you are working with?
Hi Siqi
I have followed the steps except for creating new resources status groups concrete. I will still uses system statuses and assign status on selected resources on system statuses instead.
However, it still does not shown up in ipad...
Yes, both field and 4D pro is the latest one.
It would be best if you can attach a screenshot or record a video for me to troubleshoot. At the same time, I put the steps to update status in Field for your reference. If you still cannot see the resource status, we can schedule a call.
Due to an error I have uploaded the video to google drive instead, you can down from link below.
https://drive.google.com/drive/folders/1zrzxjkw6uqHSMhIGFFZ5JjKTVQqZAda4?usp=sharing
Thanks for assistance!
