I want to assign an Apperance Profile. Therefore I need 3 conditions.
1. I only want Tasks from the same segment which is written in the column "Name" of Task (in this example " TTT")
2. I only want the Tasks which have the user field value "XXX" and "YYY" in the User Field "BB"
3. I only want the tasks, if they have the same start date.
That is what I got so far:
Hi Margaretha,
I want to first make sure if I understood your conditions correctly -
Once you have specific Tasks filtered out based on the above conditions, you want to assign the Appearance Profile, "XXX + YYY" to ALL the Assignments within the Task?
Hi Arpit,
the first and second points are right, the third one not really. I don't want that they have a specific date, I want that they have the same Start Date (in that case they also would have the same End Date, if that matters). Synchro should compare all the dates and if two tasks have the same start date ( and all the other conditions) then it should assign the Appearance Profile. And yes I want to assign the Appearance Profile to all the Assignments within the tasks.
I hope, I could clarify it a bit.
Thanks for your help!
