model disappears when I turn iRay mode on.and in export mode i can seen only black screen
Hi Dayesh,
Can you please confirm if you have a dedicated Nvidia graphics card? Also, make sure you are working in DirextX mode under Options > 3D View > Advanced > Drivers.
Option is turned on and my system is above minimum hardware and software requirements, still facing same issue
This may be better handled by our technical support. You can send an email referencing this post and any screenshots that might help, to synchrosupport@bentley.com.
Thanks!
Issue is solved
That's great! Can you let me know what it was?
Reinstalling synchro solved issue
Answer Verified By: Arpit Prakash
