I have two questions regarding .bim (local synchro file export) model syncing.
Ankur Ashesh - would you please answer the above questions?
Hi, Is there any update on this?
Yes - you can resync the scene by reloading the iModel as a new scene. It will look to see if you already have a LiveCube with the same model name and then it will re-import into that model (or at least it should).
Thanks Jaqueline & David,
This did help in syncing the model. But now a new issue started appearing. As soon as the sync finished the entire Lumen RT scene starts flickering. This flicker is appearing in both the main window and movie editor window. I have also attached the link to the clip, which shows the flickering in the file.
Link to Video
Thanks, Jacqueline and David,
This did help in syncing the model, but as soon as the sync got complete a new issue started appearing. Now, the entire main window and movie editor window is flickering continuously. I have also attached the link to a clip which shows this issue.
Link to the clip
