This is going to be a rant in a feedback disguise:
what is the point of having a 3D model when I cannot import any information besides a useless element id?
when I organize my 3D model object into construction elements through the resources, I need the field operators to see exactly how I prepared to work for them: why should I spend so much time in organizing resources and user field if the control project shows only those useless information. In this piping case, the information about the spool is completely lost, so the supervisor, when reporting a status update, should manually select every single piping component to report the status.
there is a great idea behind the platform, but far cray from being a useful tool in construction...
I hope this platform will mature quickly.
Any updates on this issue? This really seems significant
unfortunately no improvement has been made ... Wondering if Bentley has ever looked at this comment.
Hi Francesco, May I know which 3D Design tool are you using? & what is your model import workflow? is it thru iTwin bridges or using SYNCHRO plugins?
Hi Manoj,
I am using exports from Navisworks via plugins.
actually this is not really important as I organize the construction model via Resources in Synchro 4D. We need to see Resources in Synchro Control/ Synchro Field as modelled in Synchro 4D.
We had discussions last years and looked like this was going to be implemented, but as of today nothing has been improved.Regards
