Synchro 6.1.1.1 Plugins install issue for Revit and Navisworks
I am trying to install Revit and Navsiworks plugins after installing Synchro (same version plugins), but I am getting the following error: "Navisworks is not installed or is not found on your pc"
I have both Revit & Navisworks 2020 installed and fully working.
Anyone had the same issue or can assist?
Jo
