P6 XML Import Fail
Hai, I wanna ask, when I import the XML file into Synchro. there's a difference amount between the material cost (somehow Synchro split into something undefined). for example concrete $100 in P6 dan suddenly it's changed to $73.3m3 and $27m3 is defined as a new item. Can I get an explanation about this?
Thank you.
