Hi
Everything when I click a 3D object it always ended selecting invisible unwanted 3D object. Although this can be solved by highlight, it kind of... odd. Is there is a way to control this selection?
The below is an example of clicking on a place that is invisible in right hand of view and ended selecting the object at the same coordinate on the left hand view.
Hi Edgar,
This is defintely an odd behavior, not by design for sure, and I was unable to replicate it on my test project. Is there a specific setting I could be missing? Can you please confirm if this is an isolated scenario for that specific model or you can recreate this on any other model?
If this is indeed an isolated scenario, I will recommend reaching out to synchrosupport@bentley.com.
Hi Arpit
I manage to replicated the case, this only happen when Colour mode is in Resource Status, once is in this setting, you would be able to click invisible item. For Appearance Profile this does not happen. Other colour mode I have not tried. Anyway I am using v6.3.2.0
Edgar,
Can you please share the SP file for review?
Thanks!
Sure, could you send me the link to upload?
I have uploaded the file. When you test it, the configuration of 3D View to reproduce the issue is below
Left: Ignore Timeline - TickColor- Apperance Profile
Right:Ignore Timeline - UntickColor- Resource Statuses
