Hello everyoneI have a problem working with Synchro...When exporting 4D model information in IFC format, human resources and equipment that are not part of 3D resources are not exported ... Can someone help me solve this problem?Thank you
Формат IFC содержит информацию о 3D модели, но никак не о 4D. Поэтому у вас и не получается экспорт не 3D ресурсов
HiThank you for your answerI exported the schedule and resource program file that I defined in MSP to the xml file then imported it in synchro and assigned it with the 3D model... there was no problem... but now I must export all this information in IFC format because I need to analyze the 4D model...can you help me what should I do?
