I want to do animation/frame using a hidden line, Rendering but with Appearance profile colors, how do I do this ? I need the hidden line, because I do furnace refractory wall demolition and rebuild, and I need to see the lines of every individual brick ( quick outlines effect does work for this) at the same time I want to see install, remove, colours,etc
Kind regards
Pierre
Hi Pierre,
Currently, you cannot work with Hidden Line render mode and still have solid Appearance Profile colors. One option that my work is to enable Edges (3D View Properties > Visibility ), but that may introduce many other unwanted lines.
A longshot workaround would be to do some post-production video editing to remove the white areas from Hidden Line animation and overlay it on the regular Gouraud Shaded mode!!
I will encourage you to post this as a feature request here - https://communities.bentley.com/products/construction/i/synchro-construction-solution-ideas
