Has anyone run into issues with 3D solids brought into i-model that that volume field is blank in the properties tab? But was able to see that when I use the "civil quantitiee" function.
The 3D solid is a closed shape, made from ORD 10.10.
-Wayne
Hi Wayne,
The properties under Civil Quantities are calculated by SYNCHRO Modeler and they are not linked to those available in the object properties tab.
Can you check if the volume field is populated in the native file, before the i-model conversion?
Best regards,
Alex B
Hi Alex,
That's the strange part. There is volume reported under the geometry field but not with the civil quantities.
I want to double check.. Are you working with SYNCHRO Modeler? Trying to open the imodel in SYNCHRO Modeler and the highlighted properties are missing?
Alex
I am working with Don Sheldon from the Synchro team. Will keep you posted what we found.
