Hello!
I am interested in the topic of AWP and the relationship with SYNCHRO.
How is the relationship between SYNCHRO and AWP implemented?
(a question on a similar topic - Synchro 4D Pro and Synchro AWP - SYNCHRO Forum - SYNCHRO Construction Solution - Bentley Communities )
SYNCHRO AWP is a separate product that will be released under the SYNCHRO brand?
For example, the link mentions AWP as a separate product.
Upgrading from SYNCHRO Pro (and SWP) to 4D Pro (and Control) - SYNCHRO Construction Solution Wiki - SYNCHRO Construction Solution - Bentley Communities
“Construction entitlement contains visas (4D, Control, Field, AWP), Visas contain individual products. (IDs for Visas are different than IDs for products.)”
Some pages even have screenshots of the interfaces:
SYNCHRO AWP (reisoftwareth.com)
ПО SYNCHRO Work Package Server (bentley.com)
Please help me understand how the AWP method is related to SYNCHRO?
AWP is a project execution methodology that SYNCHRO supports through the appropriate application of the work process. Here are two videos that give a good overview on using SYNCHRO on AWP-driven projects.
https://www.youtube.com/watch?v=O62VToG_7TA
https://www.youtube.com/watch?v=MfT933UhsyE
The SYNCHRO AWP product you reference is outdated and is actually Bentley's ConstructSim and Work Package Server products.
Hello Ryan,
Yes, of course, we have seen both videos on YouTube refer, and carefully investigated them minute by minute.Beyond general methodologic moments, the first one contains the Tab with a set of scripts.
Could we get/sell them to End-User? I guess we need to contact Bentley Consulting, could you help with this connection?
Plus that, for the landing AWP in Russia, we should Make localization - Cyrillic description, Interface, Help, etc, or get it as a product from Vendor.
Since to our experience, AWP implemented from CII - Construction Industry Institute is the Software and Services, cost a lot - much more than Synchro 4D licenses.Any advice/suggestion, please?
Best regards, Pavel Khrapkin BIM expert NIP "Informatica" Tel.: +7(812)321-00-55 ext.258 mob.tel +7(921)963-9469 Skype Pavel_Khrapkin
Hello Pavel,
A Bentley Professional Services Colleague will reach out.
Regarding product enhancements and feature requests please submit to SYNCHRO Control Ideas Portal (aha.io)
