StoreTasks() Unable to import tasks request exception
Hi
I have this message error while importing the P6 Schedule using the load DB option
is any one have similar issue
thank you in advance
Warning: could not assign parent resource to the task
  • Hi Sameer,
    I have seen the "StoreTasks() Unable to import tasks request exception" error in the past and it was because one task ID had a symbol which wasn't accepted by SYNCHRO. Browse the task IDs in P6 and see if you can find any odd symbols.
    If that is not the case, would you be able to share with me the schedule exported as a P6 xml? alexandru.buzan@bentley.com
    Best regards,
    Alex B.
