Is there any Synchro Script to filter out the tasks with a specific appearance profile?
Hi Akshay,
Appearance profiles are Assignment properties, that are established between a Resource is assigned to a Task. As a Task may have multiple assigned Resources each with different profiles, when you run a script you may get multiple results.
With that said, you can filter out the required Profile form the results of the following script - TASK ASSIGN_UF("Appearance Profiles", STRING, CONCAT_COMMA(ASSIGNMENT.STRING_PROPERTY("Appearance Profile")))
